Automated Transfers enablement
Automated Transfers is a feature in Hilti ON!Track Pro and Enterprise. It automatically updates the location of your tools and equipment when they move between your main locations, such as warehouses, vans, or jobsites with gateways. Instead of updating each tool’s location manually, ON!Track uses active BLE tags and gateways to detect movements and update your inventory automatically.
Note:
  • Automated transfers also have a 'default' delay of 30 minutes i.e If a BLE tagged asset becomes eligible for an automated transfer the actual transfer will be triggered after 30 minutes delay If that asset still is eligible for the transfer.
  • This feature is disabled by default and needs to be enabled for automated transfers to work.
  • If an asset is already in a transit state and if the asset is tracked by a Gateway enabled location/Storage asset, a new automated transfer is not created.
Example:
You start your day at the warehouse. Ten drills are assigned in ON!Track to “Warehouse – Central.” The drills are stored on a rack near a stationary gateway, and each drill has a sensor tag.
Loading the van
You take the ten drills from the rack and place them into Van 12, which has a van gateway installed.
What the system notices
  • The warehouse gateway stops detecting the ten drills (because the tags have moved out of the gateway's Bluetooth range)
  • The van gateway starts detecting the same ten drills while the van is parked and when it starts moving.
What ON!Track does
ON!Track recognizes that the drills are no longer at the warehouse and are now regularly detected in Van 12. Based on the automated transfer settings being enabled, ON!Track automatically updates the drills’ location from “Warehouse – Central” to “Van 12.”
You do not need to make any manual changes.
What you see as a user
  • When you open the Asset Details for Van 12 in ON!Track, you’ll see all 10 drills listed.
  • When someone checks the warehouse inventory, those drills no longer appear there.
From your point of view, you simply move the tools. ON!Track updates their locations automatically in the background.
How to enable Automated Transfers
  • Settings: Automated transfers can be enabled in the company settings at the tenant level.
  • User Permissions: Only users with permissions to manage company settings can enable or disable automated transfers.
What happens after a transfer is completed
  • Alerts: Upon successful transfer, any previous unexpected asset removal alerts for the asset are closed.
  • Transfer History: Transfer History records where and when each move happened and whether it was a manual or automated transfer. Users can view the latest transfer details and the full history for each asset.
You may also be interested in Suggested Transfers! If so, please check: Suggested Transfers
You may also be interested in Automated Transfers! If so, please check: Automated Transfers Overview
