How to view & edit historic service results and checklists
Roles: Administrator & Employee | Interface: Web & Mobile
Key Points:
The following points apply to both the web platform and mobile applications:
  • Checklist is read-only after completion — When you view a historic service, the checklist is shown exactly as it was at the time of completion. It cannot be edited.
  • The service result can be changed conditionally — you can change it from 'Fail' to 'Pass' (or the reverse) only if all mandatory checklist items are completed. Otherwise, the result stays locked.
  • Asset status is not affected by historic edits — Asset status updates automatically based on the service result and company settings during active service completion. When editing a historic service, these automatic updates do not apply. You can still manually change the asset status separately if needed.
  • Template changes don't affect records — Historical services retain the original checklist data to maintain a clear record. Future changes to the checklist template will not affect these records.
Web Platform:
Viewing Historic Service Details
  • Search for the asset you need, select it, and click on “Show all historic services".
  • Select the required historic service to view the service details.
Edit Historic Service
  • Select the required historic service and click “Edit.”
  • Editable fields: completion date, service result (conditions above apply), other details, attachments, and additional information.
  • The checklist section is visible but not editable.
Mobile Application:
  • Follow the steps above to locate the historic service, then tap 'Edit'.
Note: On mobile application, if you complete a checklist for a historic service, items will appear unmarked based on the original template. Once completed, the checklist locks.
