How to complete a service with a checklist using web platform
Before moving ahead, please ensure you have the correct settings enabled for service checklist. To learn more, please check: How to setup automated asset status change for service results
Service Completion through web application
Service completion through a checklist ensures that tasks are completed in the correct sequence, properly documented, and tracked for maximum transparency.
Instructions
To complete a service including the checklist, follow these steps:
  • Go to the "Assets" section, select the required asset, and click on upcoming services to view the details in the details panel.
  • When you access the service completion page, the checklist items for that service will be displayed. These items are preloaded from the service template.
  • You must complete all mandatory checklist items before you can mark the service as "Pass".
  • Note: When mandatory items exist, the "Passed" button is greyed out until all are completed.
  • Finish all mandatory checklist items first. Then choose Passed or Failed. After that, the ‘Complete Service’ button will be enabled.
  • You can select "Failed" at any time, even if mandatory items are incomplete.
Note
  • An information pop-up will indicate that the asset status may change automatically based on the service result and company settings.
  • After completing the service, you will be redirected to the manage service page at the upcoming service tab.
  • Asset Status does NOT CHANGE for historic service or re-edited completed services
  • Anyone who can complete a service - asset status change will happen automatically.
Key Features
  • Clarity and Accountability: This approach ensures clarity and accountability in service completion, making it easier to track what has been done and what remains.
  • Modern Interface: A guided and user-friendly screen helps you to complete checklists efficiently.
  • Item-by-Item Completion: You can mark each checklist item individually as they progress.
  • Reset on Deselect: If a checklist item is deselected, the screen resets to its default state.
