March 2026 - Release Notes
New Features
Geo tag movement detection
What is movement detection
Movement Detection is a smart feature for Geo Tags that improves tracking efficiency and accuracy.
How it works
  • When a tracked asset starts moving, the Geo Tag sends a “Movement started” update, which appears in the asset details as shown in the example below.
  • When the asset stops, it sends a “Movement stopped” update, which is also displayed in the asset details.
  • These movement updates work alongside the regular 6 AM and 6 PM updates.
Why is this important
  • More frequent updates when it matters: Instead of fixed hourly intervals, updates happen if there is movement.
  • Compatible with all existing Geo Tags: No need to buy new hardware.
Things to keep in mind
  • Battery life may be affected due to additional updates during movement.
  • Ideal for assets that move frequently and need near real-time visibility.
  • Movement detection is by default off and needs to be enabled.
Role‑based geo‑visibility in ON!Track
You might not want asset locations shown on the map to be visible to every user in your ON!Track account.
With our new role‑based visibility controls, you can now decide which user roles are allowed to see geolocations on the Smart Map and in the asset detail view.
Whether you want to limit visibility to selected roles or turn it off entirely, ON!Track now gives you the flexibility and privacy your organization needs.
Stay in control. Stay compliant. Stay efficient.
Switch Account
Users can now switch between tenants directly from the web app.
If a user has access to multiple tenants, a “Switch Account” option is available under their username—allowing seamless tenant switching without re-login.
Other improvements
  • Smart Map Cluster list improvements
    • The asset preview in the Smart Map Cluster list now shows additional relevant information such as ‘Tool status’ and ‘Last seen’ date and source.
  • Asset card in Smart Map enhancement
    • The asset card in the Smart Map now will display the scan code or the inventory number of the asset when asset Brand and/or Model fields are not available.
  • Unexpected Assets Removal (UAR) Alerts Information Text
    • When an Admin is accessing the UAR alerts configuration in Company Settings, now new informational messages to explain alerts behavior are shown. Also, once admin enters the edit mode of for each of the alerts, they are shown new informational text(s) on each of the settings.
    • HEM Utilization Summary Name Change
      • The ‘Summary’ under Utilization section of HEM Asset details is now renamed to 'Utilization insights’.
8 out of 9 found this helpful
