May 2026 - Release Notes
New Features
Find Geo-Tagged Assets Faster with Search and Advanced Filters
Market Availability
All markets
Platform Availability
Web
What's New?
Finding geo-tagged assets is now quicker and easier.
You can search for an asset directly using its Geo Tag serial number and instantly access the asset record. New filter options also help you view and manage geo-tagged assets more effectively.
With the new filters, you can:
  • View all geo-tagged assets in one place
  • Identify assets that have movement detection enabled
Why It Matters
The new search and filtering options make it easier to locate assets and monitor their tracking status. This reduces the time spent searching for asset information and provides better visibility into your tracked assets.
How It Works
Enter a Geo Tag serial number in the search field to find an asset instantly. Use the new filters to narrow down and view specific groups of geo-tagged assets.
Key Benefits
  • Locate assets faster
  • Improve visibility of tracked assets
  • Easily identify assets with movement detection enabled
Retrieve Service History Across Multiple Assets with a Single API Request
Market Availability
All markets
API
What's New?
A new API endpoint is now available that allows you to retrieve service history for multiple assets in a single request.
Previously, service history had to be requested separately for each asset. The new endpoint simplifies this process and supports large-scale reporting and integrations.
Why It Matters
Retrieving service information across multiple assets is now faster and more efficient. This helps reduce API usage, improves integration performance, and makes service reporting easier.
How It Works
Use the new API endpoint to request service history for multiple assets at once. The endpoint supports:
  • Open and completed services
  • Date and time-based filtering
  • Paginated results for large datasets
Returned information includes:
  • Asset details
  • Service status
  • Service dates
  • Due dates
  • Service titles and types
Key Benefits
  • Reduce the number of service-related API calls
  • Improve Power BI and integration refresh performance
  • Simplify service reporting across multiple assets
  • Support larger datasets more efficiently
For more information, please click here.
Improvements
Improved Asset Model Selection for Hilti Assets
Market Availability
All markets
Web
What's New?
When adding a Hilti asset, you must now select an official Hilti asset model.
Custom-created models can no longer be used for Hilti assets. If a required model is not available, the model field will remain empty until the model is added by Hilti.
Why It Matters
Using official Hilti asset models helps keep asset information accurate and consistent across your organisation. This improves reporting, tracking, and overall data quality.
How It Works
When creating a Hilti asset, select the appropriate model from the available Hilti asset models. If a model is missing, Hilti will add and maintain it centrally.
Key Benefits
  • Improve data accuracy and consistency
  • Enhance tracking and reporting capabilities
  • Create a more reliable user experience
22 out of 30 found this helpful
