View the latest local inventory results in Reports
Market Availability: All markets
Platform Availability: Web
What's New?
Your local inventory results are now available directly in the Reports section. The new Local Inventory Report provides a central view of the latest inventory results for locations, storage assets, and employees across your company. You can also download individual results or merge multiple results into a single Excel file.
Why It Matters
You no longer need to search through emails or manually combine inventory results. Everything is available in one place, making it easier to track completed inventories, review results, and identify missing or misplaced assets.
How It Works
- Go to Reports and select the Local Inventory Report (assets) system template.
- Select Generate Report to view the latest inventory results.
- Search or filter the results and download individual reports or merge selected results into a single Excel file.
See what prevents employee deletion
What's New?
When deleting an employee, you can now see their active assignments directly in the deletion flow, including assets, quantity items, and locations. You can open the related records directly and update the assignments.
Why It Matters
How It Works
- Start the employee deletion process.
- Review the list of active assignments.
- Open the related records and reassign them.
- Once all active assignments have been cleared, complete the deletion.
Customise Views for New Hilti Assets
What's New?
Why It Matters
Focus on the information that matters most to your onboarding process and manage newly onboarded assets more efficiently.
How It Works
Open the New Hilti Assets view and select the columns and layout you want to display. Your customised view helps you focus on the information that matters most.
Update Your Mobile OS to Continue Using ON!Track
Platform Availability: Mobile
What's New?
Why It Matters
Keeping your device on a supported operating system helps ensure a secure, reliable, and up-to-date ON!Track experience.
Redesigned API Documentation for Faster Development
What's New?
We have redesigned the API documentation to make it easier to find information, explore available APIs, and start building integrations faster. The updated documentation includes improved navigation, built-in API testing, and code samples in multiple programming languages.
Why It Matters
The new documentation helps developers find answers more quickly, reduce setup effort, and work more efficiently when building integrations with ON!Track.
How It Works
The updated documentation provides a single place to discover APIs, review available resources, and support integration development from start to finish.
