The Smart Tag AI T320 helps you keep track of your tools and equipment without scanning them manually. It is a small and durable tag designed for handheld and cordless tools. The ON!Track mobile app and ON!Track gateways automatically detect the tag and show where your tools were last seen. This helps you find tools more easily, reduce delays, and keep work moving. |
Specification |
Details |
Model |
AI T320 (standard) |
Connectivity |
Bluetooth® Low Energy (BLE) |
Dimensions |
32 x 22 x 5 mm |
IP rating |
IP 67 (IEC 60529) |
Barcode type |
2D barcode (Datamatrix ECC200) |
Battery |
Built-in, not replaceable |
Communication standard |
Bluetooth 4.0 |
Radio Frequency |
7 s |
Frequency |
2.4 GHz |
Operating time at 23 °C |
4 years |
Operating temperature range |
-20 - 60 °C |
Which tag should you use?
Use AI T320 for smaller tools and equipment that regularly move between jobsites, vehicles, and storage areas, such as drills, breakers, measuring tools, and other handheld or cordless tools.
For larger, unpowered assets in areas without Bluetooth or gateway coverage, such as trailers or containers, use Geo Tag AI T400.
Benefits of Smart Tag AI T320
- Find tools more easily: See where a tool was last detected to help locate missing tools.
- Reduce delays: Help teams find the tools they need and start work on time.
- Make better use of available tools: Identify which tools are being used and which are idle before purchasing or renting additional equipment.
- Complete inventory checks faster: Detect nearby tagged tools instead of scanning each tool individually.
Key features of Smart Tag AI T320
- Compact design: Small and lightweight, making it suitable for handheld and cordless tools.
- Automatic detection: The tag can be detected by the ON!Track mobile app, including the Nearby feature, and by Stationary and Van gateways.
- Last-seen information: When the tag is detected, ON!Track updates the asset's last-seen location and time.
- Durable design: The IP67-rated housing protects the tag against dust and water.
- Flexible mounting: Attach the tag using adhesive tape, an adapter, or a holder, depending on the tool and its surface..
Use cases for Smart Tag AI T320
- Find a missing tool: Check ON!Track to see where the tool was last detected.
- Check tools in vehicles and storage areas: Use Stationary or Van gateways to detect tagged tools within range.
- Manage equipment information: Use ON!Track to view information such as equipment location, usage, maintenance status, warranty details, and last user.
- Activate the tag: Activate the tag before linking it to an asset.
- Prepare the surface: Clean and dry the area where you want to attach the tag.
- Attach the tag: Secure it using adhesive tape, an adapter, or a holder, depending on the tool.
- Register the tag: Link the tag to the asset in ON!Track.
- Start tracking: View the tool's last-seen information in ON!Track.
Troubleshooting guidance
- Tag is not detected: Check that the tag is activated and linked to the correct asset in ON!Track. If you are using the mobile app, make sure Bluetooth is turned on. If you are using a gateway, make sure the tag is within its detection range.
- Tool shows activity during transport: The tags are picking up any type of movement, therefore also a movement during transport can be recorded.
- Battery is empty : The battery cannot be replaced. Replace the tag and link the new tag to the asset in ON!Track.
- Still need help?: Contact ON!Track Support for assistance.
