What are the different modes of vehicle or telematics gateway (TU600)?
The four key states Vehicle or Telematics Gateway (TU600) are as follows:
Active state:
  • The Vehicle or Telematics Gateway (TU600) scans continuously.
  • Sends data every two minutes if the engine runs and the vehicle moves over 8 km/h (only for vehicle gateways).
  • Requirement: Stable power supply above 12.1V (only for vehicle gateways).
Inactive state:
  • The Vehicle or Telematics Gateway (TU600) scans continuously (it scans with a duty cycle of 50%).
  • Sends data every 10 minutes if the engine or the vehicle is not moving (only for vehicle gateways).
  • The gateway uses power from the vehicle or heavy equipment’s battery, but under normal use, it doesn’t drain the battery. However, if the vehicle or equipment isn’t used for a long time, like two months or more, the battery may run out, just like it would without a gateway.
Sleep state:
  • When the vehicle or heavy equipment’s battery gets low, the gateway still uses a small amount of power from it. It doesn’t fully switch to its internal battery at that point.
  • The gateway updates geolocation every hour and scans Sensor tags / BLE data.
  • Trigger: Van battery voltage drops below 12.1V (For HEM it is 4.5V).
Deep sleep state:
  • The Vehicle or Telematics Gateway stops sending data when its internal battery drops to 3500 mv.
  • It only sends data if the battery level is above this threshold.
Summary of operating modes:
Mode
Moving
Power supply
Internal Battery
Data rate
Comment
Basic data: GPS, Inputs (1,2,3,4)
BLE scan data
Active
Speed > 8 Km/hr (only for vehicle gateways)
Vext >12.1 V (only for vehicle gateways)
Vbat > 3.5V
2 min
2 min
Inactive
Speed < 8 Km/hr
Vbat > 3.5V
10 min
10 min
Sleep
Speed < 8 Km/hr
Vext <12.1 V (For HEM it is 4.5V)
Vbat > 3.5V
1 hour
No BLE data sent
Deep Sleep
Speed < 8 Km/hr
Vext <12.1 V
Vbat < 3.5V
Checks on Voltage level
1 out of 2 found this helpful
