Roles: Administrator & Employee | Interface: Web, Mobile
Note: Custom asset models for Hilti tools are no longer supported. Hilti assets can only be assigned using official Hilti asset models. If a suitable model is not available, the model field will remain empty.
What is Custom asset models?
- A Custom Asset Model is a reusable template for assets, machines, or tools that are not made by Hilti.
- It can be used for third-party brands or custom-made items.
- The model stores common information such as the brand, model name, image, user manual, and maintenance schedule.
- This lets you register multiple identical items quickly without entering the same information each time.
What is special about adding a Hilti Asset?
- Lifetime Service (LTS) tools: Shipped with passive tags;
- Fleet Management (FM) tools: Shipped with Smart tags for advanced tracking.
Instructions:
For Web Platform:
Main asset page: Click "+".
Manufacturer field: Select Hilti.
Select Hilti asset: Choose the asset from the list (model, serial number, etc.). For mobile, scan the barcode to auto-fill details.
Asset identification: Fields are auto-filled. Please add the inventory number and a friendly name if you need them.
Additional information: Add asset group, labels, asset type (e.g., Van Gateway), and optional usage condition.
Asset location: Choose where it lives (warehouse, van, employee).
Ownership details: These are auto-filled from SAP. In this section, we will populate things like purchase dates, order details, and FM details (where applicable).
Service, attachments, notes: Add services, upload documents, and notes.
Complete: Click "Complete" to add the asset. This will create our new asset and show it in the main asset list.
For ON!Track Mobile Application:
1. Click on the dashboard, add, select Unique Asset and fill out the details (Identification details, Asset details, etc.). Select Hilti as the Manufacturer.
2. Fill out the required details (Asset type, location, responsible employee) and click on Complete.
This process is similar and faster by scanning the tool tag.
Viewing Asset Information on the Asset Location Page
When you open the Asset Location page, each asset is shown in a asset detail view. This card helps you quickly recognize and verify the asset you are looking at.
If an asset has a name, it will be displayed normally on the asset detail view.
However, if the asset name is blank or not available, ON!Track automatically shows other useful information instead, so you can still identify the asset easily.
Here’s how the information appears:
1. Asset Name (when available)
If the asset has a name, it is shown as the main title on the asset detail view.
2. Scan Code (when asset name is not available)
If the asset name is blank or has been removed, search for the asset on the Assets page using its scan code, if one is assigned.
On the Asset details page, you can view the scan code used to identify the asset.
3. Inventory Number (when both name and scan code are not available)
If both the asset name and scan code are unavailable, search for the asset using its inventory number, if one is assigned.
You can also use the inventory number shown in Asset details to identify the asset.
For details about the different tags in our portfolio, you can check: ON!Track Supported Hardware Overview
If you want to add a non-Hilti asset, you can check: How to Add a non-Hilti asset in ON!Track
