Roles: Administrator & Employee | Interface: Mobile
What Is Allocation?
Allocation means distributing available resources or quantities within a specific time period based on supply or production capacity. It helps match demand with what is available.
This process is important because it:
- Protects plants from unexpected demands.
- Reserves planned quantities for markets with accurate forecasts.
- Helps manage shortages during critical situations.
To add or edit allocations for QTY items, follow these steps:
Adding Allocations
- Start by creating a new quantity item or selecting an existing one. Navigate to the " Allocation" section.
- Click on "add" and fill in the necessary details.
Note: If you want to add a "Consumed" allocation, you may need to first create an "Available" allocation and then change its status to "Consumed".
Editing Allocations
- Choose the allocation you wish to edit from the quantity item allocation list.
- Only certain fields are editable, such as Main Allocation, Stock Alerts, Min Stock, Max Stock, and Storage Location. Other fields remain in read-only mode.
- After editing, click "Done." If all validations are met, changes will be saved, and you will see a "Saved successfully" message.
Note: Ensure that all fields meet validation requirements. For example, stock max must be higher than stock min, and both cannot be zero.
Note:
- Main Allocation: If an allocation is marked as Main and its quantity is 0, removing the Main check will show a message saying the allocation will be removed.
- Hidden allocations can be accessed at any time by going to the quantity item's allocation list, and ensuring 'Consumed' is selected in the status filter.
- Permissions: Users with limited edit permissions may not see the option to edit allocations.
