What is scan next & allocation selection
Roles: Administrator & Employee | Interface: Mobile
Scan Next:
Scan Next lets you process multiple stock items one after another without returning to the homepage each time. It’s ideal for tasks like restocking, inventory counts, status updates, or stock corrections.
When you tap Scan Next, the next item in the scan sequence opens automatically after each change is saved, saving time and reducing extra navigation.
Note:
If you jump from one QI to the next, the details of the last QI will be saved. A toaster message will appear, and this will continue as long as you click on the Done button.
How to find Scan Next
  • Scanning an item:
    • Option 1 (restock using restock button):
      • Go to Identify and tap quantity item detail.
      • Select the restock button and tap done.
      • Returns to the Allocation Status page.
    • Option 2(restock using 3 dots\More button):
      • Select a flow: Restock, Stock Correction, or Status Change (For this article, we’ll focus on the Restock option) and tap done.
      • Returns to the homepage.
  • Click on Restock via Quantity Item list page:
    • Go to Quantity Item List, tap quantity item detail and tap Allocation Status.
  • Clicking on Quantity Item detail page
    • Go to Quantity Item Detail.
    • Select a flowby clicking on more: Restock, Stock Correction, or Status Change (For this article, we’ll focus on the Restock option) and tap done.
    • Returns to the quantity item detail page.
Allocation Selection
Allocation Selection helps you quickly identify where stock activities should go by offering smart, personalized suggestions.
Recently Used Allocations
  • The app remembers your last three allocations across all stock activities: Restock, Stock Correction, and Status Change.
  • These are saved per user and shown first when you select an allocation, making it faster to complete tasks.
    • Example: If you did a Status Change in Pune, Pune will appear as a suggested location when you do a Restock.
How the App Chooses Allocations
When suggesting an allocation, the app follows this order:
  • Recently Used Allocation – if available for the item
  • My Location – if it applies
  • No Allocation – you’ll need to choose manually.
Good to Know
  • Recently used allocations are saved per user and shared across all stock activities.
    • (Example: If a user performs a Status Change in Pune, Pune will appear as a suggested allocation during Restock.)
  • These suggestions disappear after you log out or update the application.
  • If no allocation exists for a specific item, no recent suggestions will be shown.
